Brief Description: Turtle deck formers and updrill
Intalled the turtledeck and pilot drilled formers 1 and 4. Fit formers 2 and 3 and pilot drilled. Not noted in the plans, but the outboard flanges on formers 2 thru 4 should be bent out to conform to the skin angle. Also the outboard flanges of the vertical members need about a 7 degree outward bend to conform to the fuselage taper.
Updrilled all the turtledeck and former holes for final rivets.
Need to do the final fit up of horizontal and vertical stabilizer before I take apart the aft fuselage assembly to debur everything before final assembly and riveting.
